Autor Tema: Total Commander  (Leído 29511 veces)
  • -Tu has dado: 456
  • -Tu has recibido: 1662
Total Commander
« en: Agosto 12, 2019, 01:44:25 am »
Total Commander v9.22a
  • Two file windows side by side
  • Multiple language and Unicode support
  • Enhanced search function
  • Compare files (now with editor) / synchronize directories
  • Quick View panel with bitmap display
  • ZIP, 7ZIP, ARJ, LZH, RAR, UC2, TAR, GZ, CAB, ACE archive handling + plugins
  • Built-in FTP client with FXP (server to server) and HTTP proxy support
  • Parallel port link, multi-rename tool
  • Tabbed interface, regular expressions, history+favorites buttons
  • Thumbnails view, custom columns, enhanced search
  • Compare editor, cursor in lister, separate trees, logging, enhanced overwrite dialog etc.
  • Unicode names almost everywhere, long names (>259 characters), password manager for ftp and plugins, synchronize empty dirs, 64 bit context menu, quick file filter (Ctrl+S)
  • USB port connection via special You are not allowed to view links. Register or Login, partial branch view (Ctrl+Shift+B), and many improvements to ftp, synchronizing and other functions
  • You are not allowed to view links. Register or Login
Descargas
  • -Tu has dado: 456
Re:Total Commander
« Respuesta #1 en: Marzo 15, 2020, 04:30:58 pm »
Total Commander 9.51 rc5:
  • You are not allowed to view links. Register or Login (Windows 95 up to Windows 10, 32-bit AND 64-bit!)
  • You are not allowed to view links. Register or Login (Windows XP,Vista, 7 - 10, ONLY 64-bit!)
  • You are not allowed to view links. Register or Login (Combined installer Windows 95 up to Windows 10, 32-bit AND 64-bit!)
